95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Fri Sep 22, 2006 9:21 am
bleed the system (including the damper box), and MAKE SURE IT'S ADJUSTED PROPERLY. this can cause all sorts of problems, especially if your pedal is too low. try picking it back up an inch or two. pedal too low (if it's just above the point where the clutch starts to disengage, it's TOO LOW). if that's not it, check the master and slave cylinders for sure. you can check them without buying new ones, but new ones are really cheap. like $15 for slave, maybe $30 for master, and another ~$35 for a stainless line. so for only $80ish you can have a like new hydraulic system that feels way better than rubber + damper box.
but first bring your pedal up a couple inches and see if it goes away.
