spooled240 »
https://forums.nicoclub.com/spooled240-u54828.html
Wed Jun 04, 2008 2:00 pm
WOW so the problem was loose cross member bolts, they weren't ridiculously loose but loose enough for a little bit of play. I removed the cross member like a year and a half ago when i dropped my pan for the oil drain, but apparently they were not tightened as much as they should of.
So we tightened them down and I took it for a spin, NO CLUNKING! I was about to spend 130 on new bearings too
So, if your car clunks like mine did, check your cross member bolts before buying replacement parts
