So i just woke up and went and tested the ECU code thing,
I got 34 , 53 and 13,
http://www.youtube.com/watch?v=m5oCjObl ... QcdGNfwMUd
Im going to look up whats what, i know 13 is some temperature sensor which is what i was hoping it would be because last night i was looking around the forum and some one had a problem like mine and their code was 13 which is an EASY fix.
IDK the rest im about to look them up,
IS THIS NORMAL!?!??! : After i finished with the ECU i went to start the car and it like Choked and cranked terribly and wouldnt start for the first 3 times, then it started normally, WITH THE CHECK ENGINE LIGHT ON PERMANENTLY and then the check engine light went OFF in 3rd gear 3400 RPMS ( Where it would normally go ON) and it stayed off my whole ride back home O.o
http://www.youtube.com/watch?v=OfNuRQBi ... 8d8IXaGFib
ALSO IT IS STICK NOT AUTO, and you said somthing about voltage or something, I had subs, Hids, and a PA system on my car would that have any effect?
Code 13: engine coolant temp. sensor circuit
Code 34: detonation sensor circuit
Code 53: exhaust gas sensor circuit (right)
So could you tell me more information about what EACH is, What could have caused it, WILL any lead to any future problems, What needs to be replace, AND DO THEY ALL CORRESPOND WITH EACH OTHER?
