weird brake problem with 2009 altima s since new
silverqfortyfive
since we got the car the brakes are really grabby at lower speeds
makes it a mess to stop evenly and on target
you have to apply them and then feather off a lot just before stopping
or they jerk you down hard
one odd thing is if your slam on the brakes and activate the ABS the problem
would go away but appear again the next day
now we have 20k on the car while the problem doesn't seem as bad it is still there
and are not having any luck with the local
dealers getting fixed they will not follow the FSM or be through enough
I have rented multiple Altimas and I know there is something not
right. Looked in the FSM and unplugged the harness to disable the ABS and EBD to TrSh.
Still seemed to have the problem. Maybe air water in the lines or a bad proportioning valve?
Rear left also has an annoying squeek since new getting worse.
What are your thoughts on this?
Thanks!
Modified by silverqfortyfive at 12:04 AM 3/29/2010
MaximA32
I would take it in to the dealer as it should still be under warranty (depending on the miles that is).
silverqfortyfive
okay well the altima should have been a nice car
all the rentals we had were fine brakes and trans
ours must have been a dud went to four dealerships and they said it
was fine and normal
after turning our rotors two times and needed a third when we sold it
seems that it had a stuck front right caliper all along and was never diagnosed by any of the
dealership visits; as indicated by third grinding rotor at 40k duh
we don't have the car anymore and am not sure what to think about the whole experience
it is as though the techs have never heard of a FSM for troubleshooting?
silverqfortyfive
infiniti_lineup wrote:.....
What are you the Official Nissan Sanctioned Clean Up Crew?
Every point in your response is unrelated and contradictory.
The 2009 Altima we got made in Smyrna, Tennessee was a complete piece
of s*** and I took a huge loss selling it. The dealers would not even look at
it which seems really odd to me. I even considered driving out of
state to get it fixed.
Last edited by silverqfortyfive on Sun Oct 31, 2010 10:51 pm, edited 1 time in total.
