weird boost
sr28
Car: 1990 240sx hatchback
im having a few strange things happening to me.. i had a loose belt for a while and i finally tightened it, now my car is running 10.5 psi on a sr20 with fmic intake exhaust alum drive shaft.. i was running around 8 psi before.. but ever since i tightened the belt its been running higher.. i cant tell if the cars faster it doesnt seem faster im confused.. any ideas?
sr28
also now that i tightened it.. the car has no electricity... as soon as i hit the gas everything turns on at once.. if im riding at a high rpm with no acceleration everything turns off..
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
You must have bumped a wire and possibly the volt ref harness on the back of the alt. DO you have underdriven pullies or is the alt making a grinding or whining noise? If your belt is too tight it could have wiped out the bearings in the alt and it might be rubbing internally but unless it is making a godawful racket I doubt that is it.
Abdo
Car: S13 RB25DET
Loose belt on which pulley? The Alternator right?
sr28
yeah its the alternator pulley.. when theres low electricity in the car.. like when i first turn it on.. i get a loud screeching for a few seconds... if i rev it and spin the alternator pulley faster.. the sounds goes away and all the electricity works again
