cyrus240sx »
https://forums.nicoclub.com/cyrus240sx-u12915.html
Sat Jul 23, 2005 1:29 pm
first you should fix the problem you have with the bov recirc, just make something work for now... just to make sure thats not it... then get a boost gauge, cheap ones ok... just so you can make sure your hitting boost, atfer you have those and your still not making power you might have a better idea of why not, and then you can give us some symptoms( no boost at all, boost drops off at 5k rpm etc.) then it would be easier to get a better response...
fix what you KNOW is wrong first
