I have a ebc but I have not put it in.Chezedik wrote:Sounds about right. You say that you are pulling your boost signal from the turbo directly, so if you are boosting that little, but your gauge is reading from the mani (which must be the case if you are reading any vacuum), then you are good. As far as spiking, are you running an MBC?
k so Iam a 100% sure the issues isnt with my pipeing or bov anymore because when the car just hits idle temp I can hit full boost and hold it there no problem but after a while of driving it sems like I cnat go past 5.5-6 psi. I believe the issue is with the wastegate. would adding the ebc to the system help at all in terms of pressurizing it? How can I test the Wastegate for issues?Chezedik wrote:The one on the top is for a boost controller, yes. It is to allow the unit to be pressure compensating. So that when you divert 3 psi to the top, and have an 9 psi spring then you will have 12 psi.
What I did was I removed the vaccum source to the wastegate and it would boost just fine over 10psi so I figured the wastegate is not the issue and it must be a vaccum issue. The vaccum I was using was off the outlet of the cold side of the turbo but now Iam teeing off the big vaccum line thats under the throttle body(my boost gauge and bov are off the same line).Chezedik wrote:If it opens and at the same pressure, and you have the Fire Ring in, then it is fine. You could just have a psi spring, in which case you would get better pressure with the ebc.
The way you mentioned, using a source off the turbo is what I had but I ran into the issue of the boost just slowly falling so I decided to use a different vacum source that I said above and it seems to be holding much better now. I'll try doing it the other way you mentioned as well with the vacum source off the manifold it self.Chezedik wrote:You are using the line below the TB, I would use some manifold vacuum. See the difference is in the draw. If you use port vacuum, it can behave strangely by comparison to the more consistent manifold vacuum. Also, shorten the vacuum lines as much as you can afford. Personally, I love the idea of a turbo source, with an appropriate spring, that is what I would do. Helps a lot in preventing spiking.
