This line goes to the lower portion of the radiator. The routing from factory is correct per the shop manual.
The reason I ask is because I just installed a 12,500 btu trans cooler and its getting me weird data.
I know it aint big but its 12,500 btu as opposed to the suggested tube and fin one at 3,500 btu.
I didn't have much room and I didn't want to rip my front end off.
I attached thermocouples to the hard lines, seen in the photo.
Aftermarket cooler in series with radiator.
The data is not very consistent, but here is the confusing part
Ambient temp 97°
OEM SETUP - While cruising, trans fluid over 180°- the radiator is putting heat back into the coolant about 5 degrees.
Sitting in the driveway, trans fluid is above 200° - the radiator is cooling about 5 degrees.
After Market Trans Cooler - Cruising, coolant going back to transmission goes as high as 15°
Sitting in driveway the coolant going back is about 5° cooler.
This behavior makes me think my thermocouples are swapped, but I have double and triple checked.
I TC'd the cooler and it looks like the lines are not correct. I appears the cooler is prior to the radiator.
I thought the lower radiator line is the return.
Any input will be appreciated.
