Weird back hatch issue ?
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
Strummer1
Car: ???? Infiniti JX35
Did some work on my wife’s jx35 . Pulled the battery to replace the fan and thermostat. After I hooked the battery up the back hatch will only open when the car is running . I have already tried the disconnect the battery trick . Didn’t work . What else could it be .
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Most of them will reset the controller if you hold the "Close" button on the hatch for several seconds. You should get an acknowledgement beep and then you close the hatch manually to complete the reset. If there are any DTC's in the controller, that erases them.
Strummer1
So do this with in the full open position? I tried that and it beeped twice . But didn’t manual close it . Will get it a try tomorrow
VStar650CL
Technical Expert
Strummer1 wrote:
Wed Aug 17, 2022 6:03 pm
Doesn't need to be full open, but the controller will read whatever position it's in as "full up" and stop at that position thereafter.
Return to “Infiniti JX35 / QX60 Forum”
