homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Fri Mar 02, 2007 5:22 pm
Wire nuts are not designed for high fidelity sound systems so you can get noise that way too. You're running 2 wires nuts on the same wire? Is that what you are saying? If you're referring to the speaker wire or power wire or any wire actually, then yeah, run a new complete length of wire if possible. When making wire connections in a sound system, unless it's a distribution block or something like that (designed for splicing car audio wires), then you should use some kind of car audio wire connectors, whether it's a crimp butt connector, or crimp rings for power and ground connections, screw on types etc. Generally though, you want to minimize the amount of connectors, etc. that you use, so as not to raise the chances of noise introduction, too much resistance along the wire hurting power transfer, etc. Does this all make sense?
