Jagstang »
https://forums.nicoclub.com/jagstang-u119184.html
Tue Dec 01, 2009 5:34 pm
Hmm. . . Ever since the winter came around here in British Columbia, my S14 seems to go through a minor start up struggle while trying to turn it on.
This is what happens every time I try to start the car through out in the cold. I turn the key, and then the battery struggles for 2 seconds (sounds like it's losing power), and then BAM, the car starts up.
The weird thing is the fact that the battery has been purchased 2 months ago, and I don't understand why it's struggling (600cca). . .
So anyways. . . I called our fellow niconaught Asoomal, and I told him to listen to it, and I put my cell phone on top of the battery (so that he can hear it), and then I turned the car on (which it struggled way more, and barely started). After going back to the phone, I found the phone disconnected (as if I hung up on him).
I called him back and told him it shut off accidentally etc, and then attempted a second try. I tried starting the car, but for some weird a** reason, it wasn't even turning over. It was completely dead. . . So out of frustration and shock, I got out of the car, and went to grab the phone. This is what I found. . .
The phone was surging like a MOFO. . . The screen was turning on and off repeatedly for about 30 seconds or so. . . Right then, I knew the cellphone signals was interfering with the battery as if they were magnets or something. . .
So here's the BS. . . Now my car starts up perfectly (like it used to on warm summer days). Can you explain what might have happened to fix this problem? Maybe I need to change the battery now? Or what.
Let me know what you guys experience on winter months, and if you have any experiences/solutions on this weird event.
Thanks in advance.
Modified by Jagstang at 8:22 PM 12/1/2009
