blaster17363 »
https://forums.nicoclub.com/blaster17363-u130978.html
Tue Dec 15, 2009 3:14 pm
I really need help with my car. It's been giving me these problems and I can't find out what it is.
So at idle my A/F will be at around 14/15. This is normal right?If I so tap the throttle the A/F will stay at 16/17. Boosting or not. At any speed. I really don't know what this can be. I've checked the MAF, the o2 sensor etc.
I am changing the fuel pump to see if that is the problem, but the fuel pressure gauge reads 40psi(My car has a stock pump, bought it that way, the fuel pressure reads 40psi)
Can it be the throttle position sensor? Are there any other sensors I should look at? Can the injectors not be getting enough current? I want to get this fixed.
Any help appreciated, thanks.
Modified by blaster17363 at 6:16 PM 12/15/2009
Modified by blaster17363 at 6:17 PM 12/15/2009
