weight...
wherearemypants
Car: 89-90 240 sx s-13 w/ ka24
How much exactly does an Sr20det with transmission and everything weigh... i'm wondering if i should go sr20 or ka18... they are both good motors, even tho alot of people don't respect the ka18... i really need the weight on both motors... i'm gonna buy one soon and i'm wondering if it is worth the extra to go sr... i have heard of ka18 blowinge the pants off of sr's so i don't know...
thx guys...
---wherearemypantz---
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
ive never even heard of a k18. are you sure your not talking about a ca18??
S13FASTBACKSR
Car: '92 Fastback SR powered
almost any engine that is of less hp in a stock nature can beat another engine that is of more hp in a stock nature IF its modified enough..a stock CA18 would not beat a stock SR20 unless the sr driver sucks and the ca one doesnt...idk about the weight of the motors but im pretty sure there isnt that much of a difference..you'll have to do a little more searching
draggin93
Car: Nissan Hardbody
An Sr is around 450 lbs with the transmission.
VigVoodoo
My guess is that the CA18 and its iron block is heavier.
Blown240sx
Car: 1996 240sx
CA wieghs about the same as a KA
Sr isnt much lighter than a KA. At most 40-100 pounds. I do know the LS1 wieghs 20 pounds less than a KA though
leroiboy
Car: 1989 Nissan 240SX Coupe
sr(well s13 redtop anyway)is 490, ka(sohc)is 493
VigVoodoo
Well seems like the SR20DET is about 30lbs lighter than the CA18DET
wherearemypants
my bad... i accidentally wrote ka instead of ca... my bad... i'm probably gonna go red top... i found one at jazzproparts.com... free shipping and everything... i don't know what i need besides what is there... heres what comes with it...
Motors average 35,000 miles and come with a 100% start up warranty.Engine Package Comes With:•Complete Motor•Throttle Body•Transmission 5Spd RWD (with Clutch Assembled to the engine)•Wiring Harness•All required Cables•ECU•Exhaust Manifold•Alternator•Starter•Power Steering Pump•Power Steering High pressure Line•Wastegate solenoid Controller•Wastegate actuator•A/C•Fuel Rail•Injectors•Canistor•Turbo•For Ignitor Chip, Master Air Flow (MAF), Air Cooler, Pipping Please add $595.00 to the total and call for availability.
i know i'm gonna need the chip, Maf, air cooler, and pipping, but what else am i gona need??? motor mounts??? sensors???
i came to the SR forum cause i figure all you guys have one so u would know... i wana just rip out the ka... redo the rear end... and drop in the sr... no B.S problems that usually come with drastic changes...
You guys have helped so much allready... thx...
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
Read the "where to buy engines" thread in the FAQ section of this forum. I dont think people have been happy with Jazzproparts. Dont go out with a motor just because it is cheap. Look for quality. If you have importer within a reasonable distance from you I would personally go there and select a motor. It is always good to do a compression and leak down test, look make sure all seals and gaskets look in good condition, check the turbo for shaft play and oil leak etc.
SPIRONIUM
Car: 240RS group 2
conflicting info.. i can't seem to find the thread but some dude weighed a bunch of nissan engines and the results were that the sr20det and ca18det are very close to the same weight. SR is a couple KGs lighter. They are both ~30lbs less than the ka24de. Online engine weights are sketchy, everybody weighs with their own ideas of what accessories (alternator and such) should be installed when on the scale. Theres no definate weight out online but this info seems to be the best in my opinion
