Weight reduction to HP gain?
cnickk
Car: 1994 Infiniti J30t
2004 Infiniti G35 6mt
is there any formula or general relation to weight and horsepower? for example if i take out 100lbs will i gain 2.4 HP? If so does it matter where you loose the weight in the vehical? i know this is a broad question, but i need as detailed an explanation as possible.
Q45tech
You mean to say IF I remove 100 pounds what will the acceleration gain be -------with the same engine!
Depends on where you remove the weight and if rotating [wheels, rotors, flywheels, TC, gears, shafts or tires] or non rotating body weight.
Or what will be the acceleration improvement if the driver or passengers lose 100 pounds of weight.
4300/4200= 2.38% should improve quarter mile acceleration by ~~0.1 seconds.Pretty difficult to find 100 pounds to remove except in drivers as the engine/transmission/driveshaft/diff are fixed........AC system.
The largest variance is the 22.5 x 6.4 pounds/gal = 144 pounds a full gas tank makes........0.15 secs in quarter mile. Add up coolant, oil, ps, ATF, diff, brake fluid, AC charge, washer fluid ~~ 60 pounds or ~~200 pounds of liquids.
Rotating weight reduction is roughly 3X as good as static weight, depends on the diameter of rotating component. Wheels and tires being better than a driveshaft. Obviously a oem 15" tirewheel is much better than a 17 or 20" combo since they are always heavier.
The lighter [15 pounds 4x4] forged 15" wheels found on Q45t of 1991 just offset the weight addition [43 pounds] from HICAS......accelerationwise.
Almost every pound [of the 4300 loaded] is need to haul a 160 pound driver around in comfort.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Best weight reduction can be had by getting lighter seats, if your up for that.....
Drive past Krispy Kreme instead of driving through.
There's an old thread where some guy gutted his Q down to the bare nothings.
cnickk
i may just do that. nude j30t on the way. q45tech thankyou for your detailed post i understand now what has to be done.. your the man!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
cnickk wrote:i may just do that. nude j30t on the way. q45tech thankyou for your detailed post i understand now what has to be done.. your the man!
Actually, you will be better served by starting with a lighter car with the same engine, say a Z32 NA or TT.
Then you can continue to enjoy the J for what it was designed to do.
cnickk
i have a 1986 nissan pickup not the 86 1/2 but the 4 headlight style. lol i could mess with it . i dont have enough money to make my jcar faster and dont worry im not stripping her.she has been way too good to me.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
I've always assumed 100lbs of non rotating weight reduction = 10 hp.
I dont understand how you could gain power from less weight. You could gain acceleration I guess, as in Dennis' first post.
Oh yeah, try stickers!
elwesso
2007 BMW M Coupe
Hell NICO stickers are worth 15HP...
DAEDALUS
911/Q45 wrote:I've always assumed 100lbs of non rotating weight reduction = 10 hp.
I'd say that's not far off on average, but the Q is heavy. F = maChange in force is 1:1 for change in mass. Given the Q's weight, 100 lbs in acceleration ~ 7 ft-lbs at peak.
Q45tech
The old 100=10 rule of thumb was for cars that had a 10:1 HP to weight ratio obviously 4300lbs/280HP= 15.35:1 so the ~~0.07 secs per 100 pounds might be more in line with real world results.
cnickk
dude q45tech is smart as hell. is there anything about autos you dont know?
Q45tech
What happens when you have 7 years of engineering schools and 15 years of automotive study.........owning/working on Q for 15 years.
Everyone can do it. Spending lots of ebay money on test equipment helps.
