eddiec wrote:60 pounds is quite a bit. if your trying to lose weight then every little bit helps.
you are soooo right
here's my weight reduction so far
base model -50 lbshawker g13ep 11lb battery -40 lbsspare removed -50 lbsback seats gutted -40 lbsa/c removed -35 lbsstock weight with sr20: 2535 lbscurrent weight: 2320 lbs
more than 200 lbs and i still have some to go.... that has reduced my 1/4mi time by approximately .4 seconds. that's not a lot???
if no interior doesn't keep the girl in the car, a blow off valve will :ylsuper i can chirp 4th gear with a passenger in the car.
