M45Runner »
https://forums.nicoclub.com/m45runner-u131048.html
Wed May 27, 2009 10:22 am
Keep in mind, most of the EXTRA weight are there to make M45 a luxury sedan. You can definitely stripe it out to reduce weight, but then, you get a V8 powered Altima. Here are the stuff you can remove:1. Sound deadening material - about 200 lbs2. Power motors for seats, steering wheel with telescope.3. GPS system, DVD /CD changer.
If you go extreme, you may also remove the back seat, which weight about 200 lbs, as well as the spare tire in the trunk, which is about 40-50 lbs.
So, in total, you can shave out 600 - 800 lbs and the car will weight around 3200 lbs, which is very good for a V8 with that size.
