Weight reduction Q's ??????
maka
Car: Kouki S14
as we all know our cars weight quit a bit. 2862 lbs to be precise(acording to http://www.edmunds.com). anyway, i ran into some guy that said he used to work on cars and he had told me that there is a support bar that is mounted inside each door that weighs 70lbs each. dont know if it is true or not, but our doors being so heavy, this might be true. i would like to reduce the weight of my car(w/full interior). is there any other parts that i would be able to remove to accomplish this goal? is there a popular 240sx.org popular weight reduction favorite?? any help will be greatly appreciated, and would save gas too, cause we all know gas is a mofo...
da40
Car: 1995 SE 240sx
hood for sure!the diffrence between a cf hood and oem is like 10pounds thats the easiest start
navysnail
are you talking about removing the support bar inside the doors? i will tell you right now, that has bad idea writen all over it. there is a reason for that bar, and if you get rid of it a side impact could be the end of you. the weight reduction most people do involves removing the rear seats, sound insulation, and the tar-like substance that coats the bottom of the interior. replacing the hood with CF is fine too. there is also a CF hatch with a lexan rear window that will take quite a bit off your weight.
Black on Gold
Air conditioning, Rear Seats, Spare Tire
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
i lost my spare tire, jack, rear seats, all rear carpet, all the sound deadener(tar and what have you) Not the biggest weight loss but a substantial amount.
CF hood is my next weight reducer, along with a CF hatch if i find the money for it...also try some light weight wheels and the A/C(a/c is a heavy system)
1990q45er
Remove A/CRemove power steeringMove the battery to the trunkGet lighter seats (mechanical ones.. electric ones are heeavvvyy)
pr240sx
sound deadnerrear seatbelts (all four)front lap seatbeltstar gluespare tire, jack and toolsStock exhaust (aftermarket muffler shop is WAYY lighter)manual seatsmanual windowsdelete cruise controldelete ACdelete mech fan, get electrical onessmaller batteryget a diet!!keep your interior clean and free of junkfixed antennalrear seat lower paddingupper rear seathatchback carpeting (keep the cover on the hatch)
c32c7
Car: Kouki S14
go to the gym...
thats what i do
Z Style
Car: 93 240sx Roadster
01 Pathfinder Overland
97 F350 Powerstroke
88 RX-7 SR20DET Swapped
14 Star Bolt
The sound deadening is a huge amount of weight. Especially the piece on the fire wall which doesn't require lots of dry ice and bashing. Has someone weighed all of that stuff actually, I just picked up the trash bag that I had my stuff in and it felt like a good 30lbs or so? Oh, stock suspension also ways a crap ton compared to coilovers.
Dustin240
Weight no problem. If you dont need,or see it remove it, no cash spent and right at 2600lbs give or take for fuel. -fact-
HPR
If you're going to be using your car every day as a daily driver. I personally wouldn't recommend extensive weight reduction. If you want to shave 40-50lbs aside from everyone else's suggestions. Look into fabricating an aluminum rebar front and back. Or you can eliminate them completely.
GoSideways5
Car: 1997 Nissan 240sx SE
there is NO WAY that this support beam weighs 70 lbs. the door itself doesn't weigh 70 lbs. trust me, we just switched doors on mine. it's not that heavy, i'd say 50 lbs. maybe a little more, and that's with the glass and motor.
Black on Gold
Man you dug this one out of the grave. Why post to a 4 months old thread? C'mon Boy's the questions been answered. By now he's probably already put 15k into the car
