HashiriyaGDB wrote:yes 2000 is accurate, but only with sr20. About 2200 with KA. You have to rip out all unneccesary supports in the doors and side panels as well as the front and rear (including reforming the dash). Unless you have a roll cage, this can seriously effect your drifting ability and your handling without proper modification. In your budget i'm predicting that you will only want to remove your a/c, inner body pannels and carpeting in the trunk. Its a cheap and good start.
