weight of 240
ignigknot
Car: 1991 240sx
i was just looking around and is this true what t he site says. The se fastback weighs 3,313 lbs. and the coupe weighs 2,684 lbs. I have the se and i didnt realize it weighed that much.
KDashy
Car: '97 Nissan 240SX
I dont think the fastback weighs that much. it should be a lot closer to the coupes weight.
sleepyRPS13
Car: to sleep
mine weight 3125 lbs and only a quarter of gas.
bcar240
Car: 1993 240SX HB
accord to spec sheets, the cars weight the following
S13 FastbackManual: Base: 2730 lbs. SE: 2747 lbs. Automatic: Base: 2790 lbs. SE: 2807 lbs.
S13 CoupeManual: Base: 2699 lbs. SE: 2712 lbs. Automatic: Base: 2759 lbs. SE: 2772 lbs.
That is curb weight, doesn't include things like gas/oil/coolant, luggage, or a driver.
Tsukai240
the spec sheet must be wrong. when i had my fastback se inspected it was about 3600 pounds with a half tank of gas. WTF i thought i had a light car. if this is true, i'm going sell the hatch and find a coupe
Modified by Tsukai240 at 6:05 PM 10/14/2004
TachyonS14
When I got my car smogged couple weeks back, the weight came out to 2850 lbs with me in the car. I have an S14 base model and it was like 3/4 full of gas.
ZeroS13
Those numbers seem a tad high IMO. Personally I'm looking for a base model S13 coupe as it's the "lightest" chassis.
ArticDragon192
Car: 91 Z32 2+2
My Fastback LE weighed in at 2770 with 1/2 tank of gas. Anything over 3000lbs is like vert range, lol. And I thought my car was heavy.
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Hatches weigh around 2800. End of discussion.
Did you have a system yo?
edit: I would know if we had a heavy *** car, considering the 3kgt I'm driving around as my beater weighs 3600lbs. Grr.
Nismo_Freak
Car: 89 Nissan 240SX
TachyonS14 wrote:When I got my car smogged couple weeks back, the weight came out to 2850 lbs with me in the car. I have an S14 base model and it was like 3/4 full of gas.
I think the scale was a little off.
Before - 2690 lbs. 3/4 tank of fuelRemoved Trunk StuffRemoved Passanger and Rear SeatsI/He/Ex About 3 lbs. less per corner at wheels/tires
Verified on NHRA certified scale, and I have a base model S14.
Now - ~ 2490 lbs. - Whats left lol....
BHayes_S13Coupe
Car: 1990 Nissan 240SX (Coupe)
I thought 240's weighed a lot less than that, I thought they were around like 2500 lbs! learn somethin new everyday.
mynismo
bcar240 wrote:accord to spec sheets, the cars weight the following
please look at the specs above, they are exactly correct.
once you start gutting s13's you can easily get them in the 2500 lb range. heck, one of my friends ran a 14.9 bone stock with a dohc stick (i mean BONE STOCK), basically because it weighed 2400 lbs.
s14's will weigh more. s15's will weigh even more yet.
if you are unsure what your car weighs, go to a local truck weigh station off the highway and tell them that you want to weigh your car. they only charge $10-15.
Modified by mynismo at 10:55 AM 10/15/2004
nicks240
Car: 1995 nissan 240sx
my 95 240 tips the scale at 2860 its a 5 speed with leather but its not an se
Tsukai240
3619 was the measurement. it makes a little bit of sence because my car had all the options. HICAS, cruise, abs, sunroof, ect.
ArticDragon192
Car: 91 Z32 2+2
3619 is still way too much though.
mynismo
Tsukai240 wrote:3619 was the measurement. it makes a little bit of sence because my car had all the options. HICAS, cruise, abs, sunroof, ect.
im 100% sure you've never put your car on the scale, unless you had 400 lbs of bricks in the trunk.
you must be looking at the gross vehicle weight on the door. thats with full capacity (4 people), full liquids and full cargo room taken up (full trunk). you can't look at that figure.
go weigh your car.
Tsukai240
well then the scale at the inspection(aka smog) station is farked up because that is what the report said. whatever
cesarmd7
Car: 90 300ZX 2+2TT
maybe it was 2619 instead of 3619????
mynismo
Tsukai240 wrote:well then the scale at the inspection(aka smog) station is farked up because that is what the report said. whatever
it is, because if you use common sense you'll figure out that there is no way in hell it weighs anywhere close to 3600 lbs.
i didn't even know emissions had a scale? maybe they just wrote down the gross vehicle weight on your vin sticker in the drivers side door jam.
240Kuminachu
mynismo wrote:it is, because if you use common sense you'll figure out that there is no way in hell it weighs anywhere close to 3600 lbs.
thats exactly what they did...
Tsukai240
ohh you all are right
underground
Car: 98 RB26DET 240SX
My RB26 S14 with 3/4 tank of gas weights 2925....
And I have SE with sunroof, 18" wheels, tons of added weight....
