240marcuSX wrote:hatch wall carpeting, plastic rear speaker panels, and rear floor mats
If you look at the picture on my website, it's a little convoluted because I piled so much stuff on there. In retrospect, it would've been a better idea to do some of it individually. Without being ableto go back in time and look at everything, it's difficult for me to say what the issue was. I might've mixed the numbers up, but it's doubtful. The "hatch wall carpeting" was heavier than I thought it would be, primarily because it has some sort of weird fiberboard backing.
240marcuSX wrote:wiring & relays
I was very pleasantly surprised about this. If you look at the weights on my webpage versus the ones in the pictures, you'll notice that the two scale readings, when added together, are 2.5 pounds more than the number in the table, and this is because one box weighed 1.0 pound and the other 1.5. As for 25.8 pounds of wiring and relays seeming heavy to you, I don't know what to tell you to reassure you. But there is a lot of wiring that was cut out. Three things that might help you visualize that number:1) The whole harness in the engine bay was was chopped, much of it eliminated, and then relocated to underneath the dash. Only one of the 2 engine bay fuse boxes was kept since the headlights are non-existent. This eliminated fuse box is part of the 25.8 pounds.2) Eliminating the rear defrost saved a lot of wiring weight because of the thickness of both positive and ground wires.3) This weight includes the seatbelt computer, which is probably a pound by itself. It also includes some light bulbs, relays, anda few small electrically-related plastic pieces. The pictures I'll upload show this, however, so hopefully it won't be misrepresented.
I made sure that the boxes contained only wiring and relays, with the exception of the seatbelt computer and the aforementioned items. No bolts were in the bottom or anything, because I specifically checked before I took my measurements.
240marcuSX wrote:i dont know about those seats either, i mean i guess if theyve been weighed that many times, its gotta be about right, but it just doesnt feel like twenty pounds.
Well, I've learned one thing from this exercise, and it's that I cannot trust "feeling" worth a chit. My perception of what something weighs is almost always very far off from what it really weighs. Keep this in mind when bringing my empirical data in question.
240marcuSX wrote:when you start questioning the results of even one, it makes you question the accuracy of the rest if the same scale was used. but the rest i guess are about right, i cant tell the difference between stuff that weighs so little. especially since several pieces were weighed together at one time.
This is understandable, and I am currently endeavoring to ensure the scale is calibrated properly. None of the weights made a mental buzzer go off though, as all seemed reasonable. Even down to the sound deadening, which surprised me because it was much lower than I expected.
I will probably weigh the smaller stuff with a postage meter that tops out at 70 ounces, simply because it's probably more accurate than the one I have been using, at least in that tight weight range.
240marcuSX wrote:but i do appreciate someone taking the time to weigh all that junk.
Thank you. Glad to be of assistance, despite the interrogation.
