i know that, but good two piece rotors will cool better than stock and should make up for it somewhat. with good fluid and pads, it should be able to handle anything i can throw at it.Bronze MFP wrote:Unfortunatly a heavy rotor helps with heat absorbtion and dissapation.
Yes, that's why ppl don't usually go thru the trouble.eddiec wrote:if you use the alum upright, don't you have to change out the lower shock mount to match? the z32 and s13 use different rear lower shock mounts.
If you are talking about rear camber control arms, i have a pair for sale since I installed my cusco arms. fyibrokeAs240sx wrote:If you REALLY want to save weight
Keep stock setup, upgrade to better pads & rotors, then install rear aluminum spindle -> you save 7lbs or so & also do s14 rear control arm if you have an s13.
Usually, ppl don't upgrade those unless they are doing the rear zbrake conversion, but hey, if you want to save weight that badly, there's one way to go.
Yes. You need a fork-type rear shock mount for it to work. If you have coilovers that have ride-height adjustment via shock mount, you can simply buy a new pair of shock mounts for the z32. The threads are usually the same.eddiec wrote:if you use the alum upright, don't you have to change out the lower shock mount to match? the z32 and s13 use different rear lower shock mounts.
Has anyone verified this? Does it affect other things like overall height, etc? If it bolts up, AWESOME! Another reason for more ppl to do it who haven't done too much suspension yet, .crzycav86 wrote:If you have shocks, you can get rear shocks from a z32. They bolt up to the rear of the s13.
Because the thread title is "Z brake upgrade"... HAHAHHAHAHA, i'm kidding. Yes, those are also a good alternative, plus there will be much better wheel clearances.skydragoness wrote:No one's mentioned Q45 brakes at all. Why is that? They're better than OE, but not as much overkill as Z32 brakes are. I'm sure there isn't as much of a weight gain with those vs. the Z calipers too.
The diameter is the same as the 300zx and it's 28mm + calipers are iron. The best option I see is the 26mm aluminum caliper. I remember that in "project silvia" of scc, the weight difference was something like 2 pounds max w the 30 mm one.skydragoness wrote:No one's mentioned Q45 brakes at all. Why is that? They're better than OE, but not as much overkill as Z32 brakes are. I'm sure there isn't as much of a weight gain with those vs. the Z calipers too.
It fits, but spring rate and shock dampening are significantly different. Spring is swappable though. I hear one of the skylines uses same strut design, but w/240 specs.crzycav86 wrote:Well, I haven't used the shock myself, but I first heard it from a guy on zilvia. Then it was verified by a prominent member here on NICO(I think it was smith).
good info, i didn't know about the curved rotors, but it won't matter if i swap in two piece rotors. disk brakes australia has specs on thier website but i couldn't find anything to fit them either. here's their catalogue.http://www.dba.com.au/dba_cata...4.pdfto cut to the chase, they are 296x32 and 54mm total height, the only thing i can't find is the mounting face thickness. it's probably the same as the z32 rotors. a 7mm face thickness will give it about a 15mm offset or about .7". most hats are around 2" so it's a bit challenging to find something that works.Chingon wrote:
You mention the gtr r32's as well. Apparently they are the lightest of all, despite being 32 mm. I looked into this venue, because as you may already know, it has 30% better cooling, due to the curve vanes inside the rotor. I also looked into the wilwood route to see if I could piece together a set of 2 piece rotors, but having no dimensions for the originial rotors this proved difficult.
to be honest i am mostly going for the pedal feel and bling factor of the fixed calipers. i could just get good pads and lines for the stock brakes but i don't want to.skydragoness wrote:No one's mentioned Q45 brakes at all. Why is that? They're better than OE, but not as much overkill as Z32 brakes are. I'm sure there isn't as much of a weight gain with those vs. the Z calipers too.
