DanielC »
https://forums.nicoclub.com/danielc-u110482.html
Wed Dec 31, 1969 5:00 pm
Old hot rod saying. "Anything can be done, given enough time and money"
I have not done this swap, but I have owned a 320, and a 520 with the 1200, and 1300 engines, and I currently own most of three PL-521 pickups, and a L-18 with a cracked cylinder head.
The L-16 is a much taller motor, due to the OHC, but it is a much better motor. You probably need a transmission that will bolt on the L-16, but there are many 4, and five speeds. I seen to think that the 320 I owned had a non syncro first gear, you could not down shift into first, without doubleclutching, or stopping. The L-16 was used in the early 510 sedans, and there is a lot of information on that engine there in websites devoted to the 510. The L-16 is 2/3 of of a 240Z motor, so even some Z car sites are helpful
You probably need to change the motor mounts, both fronts, and the rear. The transmission shifter may come through the floor in a different place, maybe even where the seat is. You might have to change the driveline length, and the coupler where it goes into the transmission. The regulator for the alternator will have to come with the newer engine, again I think the 320 I had had a generator, and not a Alternator. Some wireing will have to be changed, due to different distributer location.
This is not a comprehensive list, many other changes might have to be made. Expect the 320 to be not running for a while, if you do a motor swap. A donor truck would be handy to have, or even an example nearby that you could just look at.
Rebuilding the current engine would get the 320 running much sooner, I understand that engine series is used in some current forklifts, so parts are available. I know much less about the 320 than the 521's so some other people might speak up here, also.
There are quite a few Datsun sites on the web, they might have some info available.
