You mean AR-15?bobotech wrote:He also had a full auto M16 with a suppressor but he was having timing issues so we couldn't shoot it all that much.
Who uses an A3? It's a mixture between an A2 and an A1. Military uses A2 and A4... Only real difference is the carrying handle.Mr1der wrote:a Normal A3 M16 has a 20" barrel
the M4 is a 16" or there about...the CAR-15 had a 14.5 with a big a** flash suppressor
I wanna shoot a real AK full auto (7.62)
they're a beast.
No, the USMC and the USA use the A4. The USN? A3.PyR0NiAk wrote:Who uses an A3? It's a mixture between an A2 and an A1. Military uses A2 and A4... Only real difference is the carrying handle.
Modified by PyR0NiAk at 10:07 PM 7/20/2009
0311s that I've talked to say that full auto aks jump up and right BAD.Hijacker wrote:
I would love to fire an AK firing 7.62 at full auto. I do wonder if it suffers from muzzle jump the way the M14s did firing the 7.62 NATO.
yup.Hijacker wrote:The M16 was designed for idiots to fire. Remember, it was originally touted as never needing cleaning. Because people are too dumb to remember to clean their rifles.
Yep, and all it takes is a couple grains of sand to totally f*** one up..Mr1der wrote:
yup.
it's an accurate easy to control rifle.
it'll get dirty as f*** quick though.
gas impingement ftl
It was advertised that way. Didn't mean it was real The Army didn't issue any cleaning kits when the rifle first hit the field. It didn't take long for them to realize that it needed cleaning thoughMr1der wrote:
yup.
gas impingement ftl
M4A3 is the standard issue weapon for Army, including Special Forces. It's a tapered 14.5" barreled rifle (for the M203 and now M320), used in various Mod forms depending on squad role and SOPMOD directives.PyR0NiAk wrote:M16 = military issued... 16 inch barrel. It has Semi and 3 round burst options with a 3 choice selector switch (The third choice is the Safety). The M4 is basically the same thing with the biggest difference being a smaller barrel.
Not really ... you can learn tricks to keep one running in a dusty environment. Using grease and running the gun mostly dry helps alot. Motor oil is also another good option.PyR0NiAk wrote:Yep, and all it takes is a couple grains of sand to totally f*** one up..
I don't care, call the internet police.PyR0NiAk wrote:You realize you just bumped a nearly 3 month old thread?
Keeping the dust port shut helps also, because so long as the sand doesn't get into the bolt face you are alright. That means keeping your mags covered and knocking the dust out of them as much as possible in a mag change.
Nah I'm on Pendleton, bro.PyR0NiAk wrote:Oceanside huh? Stationed at Miramar?
Wow, nice! My little bro is there as well. You just might see him around.PyR0NiAk wrote:Nice... Al Asad right now, but home station is Cherry Point...
He's a supply, reservist goon from Tennessee. His unit is 3/24 H&S Co.PyR0NiAk wrote:What squadron?
