BDub13 wrote:Also, was looking a some chips and ECU's on Z1. In the long run, would it be better to purchase a $500 JWT chip, or $1600 AMS ECU?
I will comment only on my experience with the VG30DETT motor and what I have actually seen from other enthusiasts.
The thought of 500whp on a 300zxTT is a significant achievement at best. It is possible to just bolt on expensive components but usually in the long run, the owner gets either bored or moderately excited. As a result, a plausible desire exists to increase performance.
Performance can be desired in many ways but ultimately it's left up to the Z owner.
Often the Z owner immediately shoots for an all-out horsepower machine which can easily be gained if you have the budget and resources.
Here's what I did: For a few months I discussed with my mechanic on the direction I was headed for a performance enhancement. I made it very clear to him that I wanted to build my Z from the ground up. His responsibility; build the ultimate engine block with unlimited potential supporting upwards of 600whp. So we closed the deal on a Stage II long block engine rebuild. The purpose for doing a long block rebuild is to set the stage for power adders like turbos, NOS, and upgraded bolt-on components. A Stage II was in my budget and I was able to get all the "lickies & chewies" that make it sound nice and go wicked fast. (My dyno was 509rwhp, and I’m more than satisfied)
So if you're looking to get really cool (as in expensive) bolt on components, then you may want to consider a baseline long block engine rebuild. The significance of getting an engine rebuild is for establishing the tolerances and non-conditional loads your engine will undergo should you increase HP in an orderly staged fashion.
The VG30DETT engineers were brilliant when they designed the motor...because they had a hunch there will be a frenzy of “HP” Junkies to manufacture aftermarket parts for it. (Enter Z1 Motorsports, AshSPEC Z, ImportPartsPro et al) IMO the VG30DETT is by far one of the most artistically crafted engineered motors that can handle just about any power additions you throw at it. But be prepared, because just like most things in life...it's not perfect whereas heat and engine knock will certainly kill it in a heartbeat.
I recommend you do some research, get involved by talking to other folks (as you are in this forum) that have Z32s and get their perspective on the best approach for engine building and power build up. There are several books online that walk you through the design process. Hell, you can learn a thing or two by playing FORZA 2. Aside from just getting components, have fun with it.
Without further ado here's my recommendation to get to 500-600whp:
Think safety 1st!
1) Have a mechanic inspect your car top/bottom
HOSES, HICAS*, SUSPENSION, BRAKES, TIRES, ELECTRICAL SYSTEM, SEATBELTS, DRIVETRAIN, CLUTCH, and STEERING RACK
...Replace/fix if necessary.
2)Do an engine pull:
TIMING BELT, SHORT BLOCK or LONG BLOCK, REBUILD KIT, EGR DELETE, ECU HARNESS, >STAGE 3 CLUTCH, REAR MAIN SEAL, transmission MOUNT
...replace/fix if necessary and do your cosmetics while things are out (e.g. powder coat valve covers, balance tube, engine bay, etc)
If your goal is 500-600 be sure your mechanic rebuilds your motor to support only that an nothing more. Otherwise you'll just be spending too much money on a hot-rod build for a daily-driven sometime drag-strip car.
3) Power build up
MSP HEADERS, SPLIT DOWN PIPES, 1PC DRIVESHAFT, TEST PIPES, CAT BACK EXH, TURBOS w/ WASTEGATES, SMIC (Side Mount Intercoolers), RADIATOR, OIL COOLER, BOOST CONTROLLER, 555cc/750cc INJECTORS, JWT DUAL POP, TURBO-TIMER, WIDEBAND UEGO, BOOST GAUGE, BOVs, and CHIPPED ECU<-highly recommend ZEMULATOR or NISTUNE for flexibility and control an aftermarket ECU is a bit much unless it will strictly be a racecar.
...other things to consider are solid INTAKE PIPES & NGK SPARKs. Ensure your mechanic builds everything to factory spec otherwise you risk your investment going "KABOOM
4) Dyno
After it's all said and done and your check is written for about $25K then haul it off to get dyno tested. A word to the wise...safe boost is 10-14psi as long as the turbos you select can handle it.
5) Drivability
NEVER, NEVER, EVER, neglect your suspension!!!
Redo your entire suspension by a professional and lower it about an inch or two. 18x10
make the best setup as "car nut" mentioned with excellent handling and grip.
I apologize for the long post but I have to tell you that I’ve been down that road. Note to self…it never ends
