Tyler wrote:as far as WP how involved would it be to switch over?
ProudNissanFreak wrote:If you're using GoDaddy for hosting, you can install WP directly from them for free.
I would go that route if that's the case, Wordpress isn't hard to install but if you can do it directly through them then that just saves more time and is less hassle to worry about.
Once that's done it's just a matter of installing a template you like and the proper plug-ins, which I can help with both. I can build you a custom template if you like, I can make one pretty quickly whenever you're ready and will be able to use your current header logo. Then the plug-ins are easy as well, they're mainly to help with search engine rankings and ect plus there's a few cool ones out there if you want a nice photo gallery and a few other things.
Basically if you can get that done with Wordpress already installed, I can have you up and running with a new custom template and all your plug-ins installed in a couple of days probably(as long as nothing crazy comes up at home). After that you would just have to start copying over content from your current site. Whenever you're ready just drop me a message
