heyman421 »
https://forums.nicoclub.com/heyman421-u167116.html
Wed Apr 13, 2011 6:27 am
Any car with an ECU will pull quite a few degrees of timing when disabling the EGR. I don't fully understand how an EGR effects ignition timing or how to compensate correctly with a mechanical advance curve so I'd rather not have to worry about it.
Also, after my recent head gasket replacement went awry in every possible way, I'm all in favor of anything that will drop my cruising EGT's this summer. Other than that, I never saw a dramatic difference power-wise with it on or off, so I figured I may as well put it back on.
Removing it was more or less a gut-reaction to poor idle. It ended up being a combination of exhaust leaks, tired carburetor, 30-year old plugs and wires, failing head gasket, and a clogged cat (from a combination of the others.) Now that i've got the truck running as well as it's going to, I'm not opposed to reconnecting some of the vacuum-driven accessories one at a time.
