Has been sitting for a few years, after a new fuel pump, clean fuel and a battery she runs ehh.. yes it has all the vac lines most look great for the most part. No changes when spraying carb cleaner to check for leaks.. Going to tune up, check timing, replace plugs, wires, cap and rotor along with some other things I think.. hopefully it’s good to go after that... but..
My question is.. can I or is it possible to install a Webber and keep all the vac lines and bs to remain compliant for smog. Being in the great state of California. I get to keep it “stock” but within limits of course. Just curious if adding a Webber is possible in this state and staying compliant. I would love to remove all the vac lines etc ... but.. I think I’m stuck with them for now..
And ideas suggestion or input?
TIA Z
