weather temp question for car gurus!
pae9132
Car: Modified 03 V35
I just moved to El Paso, TX from So. Cal and there is a large temperature drop here. Should I stick with the recommended 5-30 (royal purple)? or should i change it due to the weather hitting freezing temps Thanks!
Jacko3
I doubt your temperature in el Paso will ever drop below the range for 5w - 30. What temperature drop are we talking about here?
pae9132
it's gotten below freezing...i'd say around 30...but it could possibly drop more...just not sure if it should be changed as a precaution...i'm not used to the weather out here
Jacko3
you mean 30 below freezing? Go online and search for a site called the car bible. I think they talk about temperatures for different oil grades.
zozoka1212
Car: 08 Infiniti G35x
He talked about 30 or below. Not 30 below freezing. I think.
Here is his temperature for the next few days. They hit 30 some where next week at nights.
http://www.theweathernetwork.com/weather/ustx0413
Here is mine.
http://www.theweathernetwork.c...hto=f
Looks like we 'll have 10 inches of snow next 2 days.
Bring it on. wooohoooo
About the oil... I would stick with the 5-30.
zozo
DevonD
Car: 96 Nissan Maxima SE
I wouldn't worry about it at all. up here we deal with -20 Celsius almost daily. that's -4 Fahrenheit for you guys. our cars start just fine with 5W-30.
smockers83
Car: 2006 G35 Coupe
5W-30 for winter, 10W-30 for summer. Or you could stick with 5W year round. 5W has an operating temperature good down to below 0 degrees F.
If you really want to go hardcore, what they do in the extreme cold areas (like above the Arctic Circle) is use synthetics in the winter and conventional in the summer.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
5w-30 for winter, 10w-30 for summer
thats what i run
damn near freezing or below all winter.
marlin29311
Car: 2008 Infiniti G35x
smockers83 wrote:5W-30 for winter, 10W-30 for summer. Or you could stick with 5W year round. 5W has an operating temperature good down to below 0 degrees F.
IIRC 5w-30 flows at -50 degrees F....or something low like that. You don't have to worry about using 5w-30 where you live...it's only our canadian brothers that should worry about maybe using a 0w in the winter.
pae9132
Thanks! I will stick with the 5-30!
