n_r_child »
https://forums.nicoclub.com/n-r-child-u9229.html
Tue Aug 05, 2003 4:17 am
I have a '97 Pickup which runs well, even with 132000 miles. It began life in southern NM, and now resides in Michigan. Why do I mention that? Because since I moved here 2 years ago, I've noticed a little hiccup in the truck's performance. It seems once the fall rains hit my truck has learned some bad behavior. When it pours out, the truck runs well. When it is sunny out, it runs well. But when there is moisture on the ground, leaving stop lights can be an adventure.
The truck acts like it is almost out of fuel, stuttering and threatening to stall. I have no acceleration. It clears up after 5 minutes of driving, and really only occurs during the previously mentioned atmospheric conditions, making it difficult to diagnose.Last year I changed the plugs, wires and even distributor cap but didn't notice any change.
Yesterday, it did it badly enough that the Service Engine Soon lit, though it did eventually turn off (three errands later, 2nd time I had started the vehicle since the problem occurred)Any thoughts? Anyone else with this experience? How did you solve it?
Thanks.
