... that's already been said a couple posts up?jetroy240 wrote:If the tires wear looks like it's feathering, ur rear tire is toe-out, if it's smooth inner wear pattern, mostlikely u got too much negative camber.
onosqv wrote:depends on how wear patterns look.
if it's smooth - most likely camberif it's feathered - most likely toe
Drakelee, all you really had to do was a lil search on google, nico, etc...
toe out in the rear... eeewwwwwwww.
