weakest parts in a ka
drifter183
ok i need help:help :help :help what r the weakest parts in a ka with 300-350 hp.i know the rods are weak i have broken them befor. i am thinking of selling my 240 for my friends mr2 if i cant get my motor to 300-350hp i will get a stroker for 1200 my head redone 900 and a venom vcn 1000 kit runnig 75 shot (pluse the basic i/h/e and clutch) what parts am i going to have to replace and how much is it gona cost thanx for any help u can give me
Daunttless
If you have a Manual Hatch I'll buy your 240. : )
Chezedik
Car: 1991 Nissan 240sx
Where have you found a stroker kit?
drifter183
u can get a custom stroker kit from paeco industrys they make allot of costom parts for relitivly cheep
http://www.paeco.com/home.html
Top Speed Coupe
Car: Cars
If you are having problems making 300 - 350 hp on spary u have some tuning problems. I know some huys pushing close to 400-450+ range on stock internals and head. Maybe the way u ar tuning the motor could be a problem. Maybe a stand alone or chipped ecu will help???
Dattebayo
what is a standalone. Is that one of those you hook up in line with the ecu or am i just crazy
WDRacing
standalone= a ecu system that works all by itself, Haltech, Motec, SDS are all standalone systems. A piggyback would be inline with the stock ecu
Dattebayo
whats the price range or where can i find them. It sounds like i should move to a new engine management system anyway... high octane is killing my wallet.
DonDonati88
Not cheap...say 1500.00
240SXtreme
Car: racing, cars, music
im new to this club, and i need some help, i dont know if its my car, but my first and second gear suck, and mostly all my power is in 3rd and 4th, does anyone else have this problem?
Dattebayo
sounds like your driving a SOHC. make a new post with that question.
APEXi240
Car: 08 Nissan Versa S hatch
2BN_S13 wrote:whats the price range or where can i find them. It sounds like i should move to a new engine management system anyway... high octane is killing my wallet.
What does a standalone have to do with high octane? If you can't afford high octane you can't afford a standalone. A standalone won't allow you to run regular gas, lower compression will.
Dattebayo
umm ok jwt says you can with their upgrade im SO SORRY if a standalone cant do that. thats why i asked the question in the first place. prolly cause they retard the timing but still my options are open and im asking.
Aries
Car: LT1 240SS
Well, Fuel Management is an option for lower octane gas...It will just use more of it to compensate.
DFI, Speed Pro, and Haltech are all valid options costing between $1500 and $3200 for the system. Installation will run about another $2000.
It's not cheap, but it is a good way to go if serious modifications are planned fro the future.
Dattebayo
yeah ok but after the fuel management is put in what do the ratios change to? am i using twice as much gas or what? the reason im asking is if i put it in my car and basically spend the same amount on gas its not really a worthwhile effort UNLESS im missing something here like some other plus to this new system.
Aries
Car: LT1 240SS
Realistically, you'll be spending the same ammount on gas no matter what.Higher octane, lower octane...It all evens out when you add everything up.Sure you may spend less on a fill up, but you'll fill up more often too.
See my point?
Dattebayo
yeah exactly what i was getting at as well... awwwshoot. well i have learned to cut on costs with add in octane booster (though it just isnt the same) and im not sure if thats really bad for the car or what. It stops pinging when i put it in with 93 octane.
TrunkMonkey
Car: 2000 Lincoln Navigator
2BN_S13 wrote:It stops pinging when i put it in with 93 octane.
if you actually have sohc pistons in your dohc then you should be using no less than 93 octane anyways.
-demetrius
Aries
Car: LT1 240SS
What Demetrius said!
Dattebayo
umm read a little closer guys. i said it stops pinging when i put the octane boost in. sheesh. it still pings a little on 93 without the 104 boost. and it runs WILD when i use 118
TrunkMonkey
ouch!
i just noticed that you're using 90mm pistons. out of curoisity how much compression do you think you're running?
-demetrius
Dattebayo
its got to be close to if not over 12 to 1 so ouch is right. How much does a compression tester go for? i want to check so i know when i get my computer upgraded in the spring (be nice to have one anyway).
TrunkMonkey
i can tell you now that you're pushing 11.9:1...unless you had you're head milled, then it's more.
-demetrius
Dattebayo
no ihavnt at all. thats a good idea but im worried about the valves smashing into the pistons... i dont know i might just get a smaller head gasket if i want to squeeze out a couple extra horses. Plus if im going that far i need to build up my head (not like i dont need to now but i dont drive the 93 that often).
TrunkMonkey
you do realize that there's no way your going to be able to run on pump gas right?
no standalone or ecu upgrade is going to fix this. and even if it did work, you're still going to be pushing it on 93.
i bet you're burning oil too.
-demetrius
Dattebayo
yeah not too much though. The exhaust smoke isnt really blue at all. I think i must have gotten some good rings, but i know theyre gonna have to be changed after a little bit, maybe those swedish rings would help? Well as for the octane issue i figured that but just hoped somebody knew something i didnt. Oh well i gotta go for tonight so maybe i catch ya later in the week. thanx demitrius.-Dave
