Weak start issue
infinitgkid
Car: '06 Infiniti G35 Coupe
On my most recent (last weekend) trip back home I realized that my G is having an issue on start up.
I put the key in, turn it, and it cranks up just fine, and then instead of the normal start that G35's usually provide; I get a weak (almost sounds like I'm choking it) start. Also, it's not a consistent either. For example, if I let it sit overnight and go start it, it starts up fine. But if I drive it and then let it sit for like 10 - 15 minutes then the issue occurs. My first guess was the spark plugs, but I could be wrong?
Thanks for any help.
sc_coupe
Car: 2005 Infiniti G35 Sedan 6MT
battery? my G was having trouble starting for a few days then the battery died. might be worth a check? just a guess
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
my G35x did this exact thing... my battery died a couple days later... lucky i was ready for it... so i kept my G close to home...
get your battery checked pronto
infinitgkid
Thanks for the responses, I'll get the battery checked this week...
Modified by infinitgkid at 3:58 PM 2/22/2010
telcoman
infinitgkid wrote:Thanks for the responses, I'll get the batter checked this week...
You can check it yourself with a battery hydrometer.
If any individual cell tests low it is time to replace the battery
Under $10 at Sears
Telcoman
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Here in Phoenix if you drive over to Checker or Autozone they will bring out a big machine and run a load test on your entire charging system for free.
infinitgkid
gwoods wrote:Here in Phoenix if you drive over to Checker or Autozone they will bring out a big machine and run a load test on your entire charging system for free.
Yeah, they do the same thing here at hole-in-the-wall Lynchburg, Virginia... I'm going to have to get it done Wednesday because a brotha has class for most of the day on Tuesday.
smockers83
Car: 2006 G35 Coupe
Does your issue occur as it cranks or after start up?
infinitgkid
As it cranks...
