Postby
Jonnie Fraz »
https://forums.nicoclub.com/jonnie-fraz-u66174.htmlSun Jun 17, 2007 7:11 pm
Like the others have said...first adjust your e-brake properly, then learn new techniques. Also search for seahorses..They are an e-brake arm that is extented to give better leverage.
Postby
Crunkrich »
https://forums.nicoclub.com/crunkrich-u36411.htmlMon Jun 18, 2007 11:54 am
If you can't get it tightened all the way from under the handle I believe (correct me if I'm wrong) there is a 'nut' that has two all-threads feeding into on the e-brake line that you can tighten up also.
