Jiggyfry »
https://forums.nicoclub.com/jiggyfry-u32872.html
Mon Aug 14, 2006 3:20 pm
Hey folks, im still pullin my hair out looking for the cause of my cars power loss. To start off I did a full tune up, plugs, wires, dist cap and rotor. Next I removed the AIV system and cleaned it up really good, shouldve removed it but im saving that for that for this weekend. Checked the timing. Replaced both cooloant temp sensors. Found 2 cracked hoses and replaced em. Checked fuel pressure- 32psi. Checked my compression and all 4 cyls are dead on 180. Did a leak down test and everything is perfect. O2 sensor was shot, so i replaced that too. Lastly I tested my coil and found the resistance to be 1.5 ohms. Had read somewhere it should be .6 ohms. Is this correct? I am running rich and do smell the famous rotten eggs smell. Test pipe on the way shortly. I removed the cat and checked it, slightly clogged. I'm sorry for the long post but im goin nuts! My 1/4 mile time is hangin steadily around 16.5! I dont have tons of mods but my time should be closer to 15 flat or high 14's. Can anyone recommend anything else ive missed? Is fuel pressure good at 32psi? Anyone have the specs for a coils resistance? Any help would be greatly appreciated! Thanks in advance!
