Shad0wXCalibur »
https://forums.nicoclub.com/shad0wxcalibur-u95338.html
Sun Apr 11, 2010 2:47 pm
I would say compared to other econocars, the Versa is quiet and the doors have a big feel to them. Compared to a full size sedan? No, but drive a Yaris or a first gen Neon and you'll see what I mean.
I did just recently try out some sound deadening to get rid of the somewhat "hollow" type sound the speakers have and to see if it would help reduce road noise further. I used a spray instead of a solid mat called Quiet Kote by Cascade I believe. I bought two cans to do the front door panels. One can per panel. I masked them off real good and had at it. Before I put the panels back on, I decided to try a 2nd ghetto layer. I used the foam eggcrate liner from our bed and cut it out to fit over the plastic liner attached to the door frame and cut out the holes for everything and stuck the panels back on. Surely ghetto but it was free and I think it may have actually done something. After my first drive, I won't tell you it made a huge difference but I did notice. Coupled with my Cooper CS4 Touring tires, it felt like I was driving something higher level instead of an econocar. The doors felt heavier and had a solid thud when you closed them instead of that hollow sound. Oh and you'd be surprised at how much those plastic panels absorb wether you sound deaden them or not. I left them off because my speakers hadn't come in yet and drove around without them and THAT was loud. You could hear everything the tires were coming into contact with. Tar strips, cracks, rocks, etc
Edit: I had the idea to put something directly behind the speaker to absorb some resonances but theres a steel beam right behind it. I just sprayed some of that Quiet Kote stuff at it. Don't know wether it did anything but my system sounds pretty decent so far. And here's a pic of the stuff
