NISTECH wrote:when its running turn on all your none cycling loads,highbeams,blower on high,rear defogger and take a voltage reading from the battery terminals should be above 12v. if its not you got an altenator going south.
Running at idle started at 14.1 voltsHighbeams/R. Defrost/Stereo/Fan High-12.25voltsTurned off everything 13.7volts
I noticed on the alternator the red rubber boot cover was slightly torn, some water possibly cause a bad contact last night. I'll be test driving the car later today after I remove and clean the battery terminals/grounds and see what I can find to fix the torn boot..But I'm guessing the alt might be going slowly or that rain really got into something enough to cause the engine to bog at idle with everything on.
