hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Thu Apr 28, 2005 4:45 am
so i'm toying with my car lately since i have everything installed now and the wastegate dumped out the side for the time being (damn it's loud)...
i have a wastegate that i don't know the spring rate on. i know it has to be less than 10 psi, because it opens up somewhat early when i give the car throttle (and a little positive manifold pressure ~5 psi). i've been slowly increasing my throttle so i can determine the spring rate of the fmu without overboosting since i have an fmu as my fuel management currently (as many of you know i want to get the new bikirom board and start playing with that when i have some free time... maybe over the summer).
so anyway i'm approaching 7 and 8 psi in my trials (have not touched full throttle yet) and i have not yet adjusted my timing (which i am going to do this weekend when i do some more trials because i may go over 8 psi). i am getting concerned that my spring is set a little too high because i'm going to be running my fmu for at least a month or two or maybe three... or maybe it will be much longer, but i want to be able to boost my car up and have fun so i've been trying to determine the spring rate without blowing up the engine because i've heard that fmu's are only good up to 8 psi...
well so i know the fuel pressure will max out around 8 psi or so and so if i continue to increase boost past 8 psi i will just start leaning out really bad and eventually blow up the engine. i'm wondering what peoples experiences with this have been because i have seen someone (man i can't remember who) that runs 10 psi on an fmu and apparently has been doing it for a while. i guess i'm also wondering what the exact limits of the engine with a fmu as the fuel setup are because chances are that i will accidentally boost up to the spring rate of the wastegate at least once, and that may be more than 8 psi...
i've been doing my trials in 5th gear for the most part because it's the least erratic for this type of thing, so i can ease on the throttle and watch the boost rise slowly rather than in 2nd where it will jump up so fast... the response with this turbo is freaking insane, which is what i wanted since i'm just aiming to balance the car out better as an overall performer, not a straight line car or a dyno car or whatever... this setup was just plain and simple bolt on more power to my car and see how it reacts... once i start tuning with bikirom and what not it will be a different story and i'll upgrade to a different turbo and other things probably. by the way i just have a little t3/t3 (with a freaking tiny exhaust side- .48)...
so anyway back to the answers i need from people...
i've got all my gauges hooked up and everything too and i have become increasingly aware of how lazy my o2 sensor is... i have a 92 fastback, so it's obd1 and it has a 1 wire o2 sensor. it's become a concern as well as i am pushing the limits of my fmu setup and worrying about how lean my car will be under heavy load at higher rpms.
so give me some reassurance or tell me i am on the fast track to blowing it up by pushing it to maybe ~10 psi. i'm not going to be doing this in a racing style way.... not quick shifting and punching the throttle... i am easing into everything at this point because i want to know what the spring rate is.
if you're wondering why i have a wastegate i don't know about all that much, well this is a complete DIY setup and i bought a lot of stuff on ebay. this wastegate is the same as the boost designs wastegate, but i don't know the spring rate. i didn't buy it from them.
i gotta say i am very impressed with this car so far. my friend and i were doing these trials last weekend. we were doing most pulls in 5th like i said while we were on the highway, but then we got off the road and came to a light and the light changed before i stopped so i dropped it to 2nd and eased on the throttleand it threw us back in our seats... he was like "well damn now you're going to have to race the rx7"...
i guess i don't have very specific questions but just read what i've said and let me know what you think i should do, or if i should just put this on hold for a while and ride my bike when i need some speed...
thanks
