We're taking on water!
A home for 1983–1989 300ZX owners!
bobo37
Car: 1987 300zx
I've got an 87 and any time its wet outside water gets into the spare tire hole and into the area for the jack and tools. Are there any common places that begin to leak that i should look at first?
onosqv
Car: '92 240sx Vert
probably coming from your hatch/trunk area.
If you really want to find the leaks, just remove any interior you have, sit in the car, and have someone run a hose all over the back of the car while you track where the leak is from.
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
common source for leaks are the rear quarter windows and the tail lights.
to fix, pull out the offending piece, clean off the old sealant, reseal.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
be sure to pull out the tool tray insert to let it dry completely to prevetn rust, I'd strongly suspect the quarter window seals as well, but you need to find and fix the leak or you'll have major rust issues in no time
bobo37
Car: 1987 300zx
Are there any bolts holding the tool kit in or can I just pull it out?
AZ-ZBum
bobo37 wrote:Are there any bolts holding the tool kit in or can I just pull it out?
At least try to do some of this on your own. Go outside and look. Come back in when you get stuck.
Return to “300ZX (Z31) Forum”
