TEST FIT!!!
Still have to paint the reflector though, prob do that tomorrow
Thanks! yah, i wanted to be a lil different, every retrofit I've seen uses the same shrouds, I thought it would look better if I mixed it a lil. The lights are alread aligned, All I have to do now is touch up the reflector and paint it. I'm using the morrimoto bi-xenon projectors with the upgraded 6000k HID's!dangeris wrote:depends on the projectors you get and where the mounting flanges are. Some mounting flanges are really far up thus you need to take more material out to have them sit right. Problem is once you get them seated, the trick is to mount them correctly so they can be adjusted.
To the OP..Nice work. Those min gatling and the Gatling V2 shrouds work nicely together!
BTW..what kind of projectors are you using?
