WD21 Factory Fog Lights Wiring Diagram Needed
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I'm adding a factory set of fog lights to my Hardbody. I have all the wiring and related from a SE-V6 and I have everything run from the switch to the bumper but I have no lights. I would like to see some wiring info if any is available. The FSMs do not contain this info, they only refer to the switch but that's it. Does anyone here have any info I can look at to make sure I have everything together properly before I start replacing bulbs and wiring? The info has to be from a 1993-1995 WD21. Thanks in advance!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
I found a relevant thread on NPORA, Fog Lights Dont Work. I didn't see a wiring diagram in the FSM and I also checked for TSBs that might have a wiring diagram, but found nothing. I hope the thread helps somehow!
