wd msd question
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
wd u are running the msd 6btm right? me 2 and I am not too sure it is working well! I was thinking about pulling it and getting enthalpy. The question is how could I reverse the modding to my dizzy? or should I just buy new dizzy and sell the msd with my modded dizzy?
WDRacing
I'm using the BTM, not the 6BTM, but they are wired to the dizzy the same way. I assume you're talking about the brass terminal bridge you had to cut and solder onto. Well, if there is enough of a lead on either side, you can solder a wire to each side, completing the stock circuit. Thats what I would do.
What doesn't seem to be working?
WD
1995240sxSE
well my car is currently 3600 miles away but is coming out here to oak harbor washington in jan. I dont think that it is pulling timing correctly, I am sending my ecu to enthalpy when I get my tax return, so I dont think that I need the btm for timing, but I might just disconnect the boost to it and just theep the msd hooked up. But if thats all i gotta do is solder a piece in that might be a quick fix
