superDorifto »
https://forums.nicoclub.com/superdorifto-u29662.html
Thu Sep 29, 2005 5:53 am
if its like the kit i bought there sould be 5 or six wires. the colors are prolly different too, so ill be general. theseare just my colors, yours will prolly be different.
-ground wire (should be black-power wire (should be red and a thicker gauge than the others-ignition wire (prolly yellow, this goes to a 12v source with the power on, i wired mine to my cigaret lighter-power to the fan (cant remember what color-temp sensor wire i think mine was brown or something
1) DISCONECT THE NEGATIVE SIDE OF THE BATTERY!!! (move the wire out of the way so it wont short anything out) first you need a good chassis ground and a place to mount the relay. i drilled the hole for my ground underneath my radiator suport for a cleaner look
2) mount the relay somewhere safe, mine is on the fender above the fusebox
3)connect the power wire to the positive wire mass that attaches to your battery
4) connect your 12v ignition source (i.e something that gets power as sonn as the key is turned. make sure you dont pick something that only gets power when the motor is running.)
5) install whatever sensor you have according to their directions.
6) hook up the fan power wires, and give the fan's black wire a good ground as well
7)make sure you go slow take your time. i soldered all my connections and wrapped everything up in wire looms. It took a while longer, but now i have that stock look that i love so much. ill post some pics later today to help you out too. good luck- get your hands dirty
