WD, would this be with the stock knock sensor or a "better" one? Cause I'm pretty sure I can do this with the Ultimate.... need to keep on researching.WDRacing wrote:I would have a knock setting simply retardy 8 degree's of timing. Pretty simple really, just like running N2O. Just a knock sensor triggering the timing retard rather then the On/Off N2O source. Have it trigger a light at the same time so you 're aware of whats happening.
WD
Quote »With a high boost motor like yours is getting to be hugetpg, I would try to avoid tuning by listening to knock. Yes, of course you should watch out for it and listen for it, but once you start getting up in the higher boost I like to go rich + retarded and then slowly back it off until I am making good power with still a safe tune. If you start dialing things until you hear knock and then try to backtrack you can cause yourself some big problems. At 20-25 psi you dont hear knock, the timing goes out and thats IT for your motor. Seriously there is isnt much room for error up there, detonation is extremely damaging- I wouldnt want to hear it at all. So that said, I dont think a more sensetive knock sensor is really worth it. You can do the same thing with the ultimate by having the fuel + timing react if the AFR goes out of wack with the O2 correction tables.
Someone correct me if I'm wrong on this, but thats pretty much my idea on the subject.[/quote]Fiz yeah man. I know. I've never really tried to hear knock anyway, but this time I'm going WB + knock sensor (either stock one or some other "better" one) to keep it extra safe.
$200 for the Innovate MS LC-1 seems good enough for some extra peace of mind. I can even remove the stock O2 and use the narrowband signal on the LC-1 to feed the ECU for close loop operation. That way I don't have to solder any more bungs to the downpipe.
But your question still remains... will the AFR react fast enough to prevent or eliminate knock with the AFR maps? What if I'm only running lean on 1 cylinder... this is were I think logging knock would be helpful.
