Way Too Rich
TwoFortyCoupe
Car: 1991 240sx w/S14 KA-T
T3/T4 .63 AR 50 Trim
Audi R8 Ibis White Paint
2007 Acura Tsx
I was having a little fun beacuse my 240 was actually working and I went WOT in first and when I shifted to second I was running extremely rich 10.0 Afr and I ran like s*** that in second all the back home. I have an SAFC and was trying to adjust it but its not really taking any tune (I do have a enthapy tune). My question is could the z32 maf have gone or is it an ECU problem or another problem?
Any help will be great,
TwoFortyCoupe
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
The safc can data log your input maf voltage right? If so your should be able to see if its a maf issue that way. Also look into your cts and injector o-rings.
TwoFortyCoupe
2007 Acura Tsx
Its showing that the MAF is fine and the car wants to take a tune now, so a new question arises... why would it be stuck at WOT a/f when I went to shift into second? ECU is messed up or something else?
compactfean
daily
Id start looking into your tps or cts.
TwoFortyCoupe
2007 Acura Tsx
Stupid question tps is obv. throttle positioning sensor cts is...?
Mercury_Hg
Car: 1993 240SX Coupe
Coolant temperature sensor.
TwoFortyCoupe
2007 Acura Tsx
Turns out I cracked a hard pipe from my turbo and all the air was spewing out of there, but also noticed my coolant temperature sensor is bad
