You can, it's just retarded. Spend the extra $100 for the safety of your engine. High flow fuel pump = rich at idle and lean under boost--both suck.Craving4Boost wrote:im confused...so u cant run a walbro fuel pump without a adjustable FPR?
my stock fpr is working just fine with a 255lph.idled in the high 14's and at wot dropped into the 12's when i was running the stock computer.SeVa-S13 wrote:You can, it's just retarded. Spend the extra $100 for the safety of your engine. High flow fuel pump = rich at idle and lean under boost--both suck.
did you happen to install injectors at the same time? sounds like some leaking o-rings.Craving4Boost wrote:haha i actually tried already....it ran so rich i couldnt even turn on my engine no more becuz it was so flooded. the fuel actaully went into the oil pan and i had to change my oil
the 270cc and 370cc injector o-rings should be the same. 3 of my injectors are using the sr rings and the other the ka rings. did you lube the o-rings before you seated them in the rail? mine all popped in with just a little bit of force.Craving4Boost wrote:I switched the SR injector O rings to the stock KA O rings to make it fit...could that had lead to a leak? it didnt seem to fit when I had the SR injectors no matter how much strength I put into it
