DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Dec 24, 2006 4:58 pm
there is TONS of information available here on s14 s13 motor differences, so i wont go into them.
you already have the s14, so take your s13 motor, and remove the intake manifold, the exhaust manifold, and the distributor. and if you have it, the ac and its bracket. dont use the s13 alternator, and i might not use the old s13 ps pump.
then do the same thing to you s14 motor. put the s14's intake manifold, exhaust manifold, distributor and other associated parts onto the s13 block that you now have.
you need an s14 transmission, because it has the crank angle sensor in the bellhousing. you also need the mt harness. the only thing im unsure of is if you need an s14 manuel tps.
use the s14 harness.
