DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Thu Oct 13, 2005 5:32 pm
its quite possible that most of the S13 things were left in for simplicity. chances are they just used the S14 head and block.
the easiest way to check and see if they really switched the entire car to S14 OBD2 is if it has an S14 MAF
S14 MAFs are just a shade larger and a little different looking from S13 MAFs, however you cant run an S14 motor with S14 ecu without that
or you could look up the number on your ecu with the ecu look up faq... however i forgot where exactly that was, so try to compare MAFs
i'm just guessing its an S14 head and block and S13 everything else
you could see if it has an S13 intake manifold pretty easily too, just look for the swirl control valve, but that wont necessarily mean anything, as swapping manifolds is damn easy
