Testing Some of the newer Griots Garage Products:
____________________________________________
1) Complete Compound for 6" Orbital
2) One Step Sealant & Wax
3) 36" Microfiber waffle Cloth with pockets
4) 6" Microfiber Fast Finishing Pad
5) 6" Foam Correcting Pad
Results and Ratings
Rating for ease of use: Five Stars! I found the 6" Microfiber orbital pad to be my favorite for correcting small defects, swirls and scratches in clear coat.
Rating for application: 4.5 Stars ~ I found the Microfiber pad my favorite for even spreading of compound across the face of the pad, very little clumping and easily brush off any
excess with your fingertips.
However coats tended to go on to a little thick in some spots and speed control would often need to be adjusted on the polisher to thin the layering effect. The Foam Correcting Pad seemed to spread a little easier without needing to speed up or down on variable control.
Rating for scratch & swirl removal: 4.5 Stars ~ Most large and obvious defects in the finish completely removed!
HoweverMany passes were needed to achieve this result, so a lot of work.
Rating for 36" Microfiber waffle cloth: 5 Stars! Wonderful at drying and also clean wiping of the polished surface, also it can be used as a drying rack for other shammy or microfiber towles. Highly recommend this product!
As always, the 6" Orbital Variable speed Polisher performed flawlessly, and with the new buffing Pads (and some of the old) the whole experience was a rewarding and came out as close to flawless as can be expected. As Larz has stated in the past..
It's a crying shame that no photograph can accurately show the depth and pop that these products provide.
there is not a camera or cell phone that can adequately display the liquid like shine of the black paint in the sun and the wonderful smell of fresh polish in the garage air. After 2 coats you tell your self just just 1 more to make sure...and then that turns into one more and so on. Polish for the love of it, use what you are comfortable with, I hope this post at least details some products to try and gets you inspired!
Pictures
