Are you using fan clutch? If so, not wise to be using a fan clutch on pulsar water pumps as they were not designed with a fan clutch in mind. You should be lokking for a water pump from a 1984-88 nissan 200sx with CA18ET or CA20E engine.silviaS13lover wrote:ok so my waterpump started to leak about a month ago, so i replaced it. all ran good till about a week ago when the bearings went out in it. it sounded like rodknock.
so i took it back to shucks and replaced it. then the one they gave me was all screwed up. the fins stuck out way too far and when tightened to the block, it wouldn't spin freely.
i took that one back and got a new one. its been one my car about 3days now and it started makin that knocking noise yeaterday. it hasent overheated at all.
do i have the worst luck with ca waterpumps, or is this a comen problem? i used the 88 pulsar one. im thinking that shucks is gay and i should return my pump for a refund then go to nissan...
advice?
not to mention another method of cooling (elec fan)boost_boy wrote:Are you using fan clutch? If so, not wise to be using a fan clutch on pulsar water pumps as they were not designed with a fan clutch in mind. You should be lokking for a water pump from a 1984-88 nissan 200sx with CA18ET or CA20E engine.
Dee
alignment wiht the crank pulleyone was built for the clutch fan drag the other wasntits all i knowPapaBurgundy wrote:Curious as to what the difference is between pulsar/200sx pulleys are? And can you get them at an auto parts store?
its were i had to go to a big storezero_gripS13 wrote:i work for autozone in ohio and we usually have em in stock at some stoor another.. usually our hub or mother store....
they were the least helpful of anyone, sorry to say and werent really willing to help me out at all. Napa was pretty helpful, but though I was confused when asking for it. I went to the advance "Mothership" or hub in town, and they had a few in stock.zero_gripS13 wrote:i work for autozone in ohio and we usually have em in stock at some stoor another.. usually our hub or mother store....
its not that.DALAZ_68 wrote: alignment wiht the crank pulley
so should you be able to use the clutch fan on a OEM Nissan fwd pump if you use the pulsar fwd pulley like in the pic ?ca18datsun510 wrote:should be fine.
the big problem is if you try to run the fan off of it, there is nothing keeping it properly lined up, so you will get vibrations and imbalance that eat up the bearings.
think of it like your wheel, and how the whole in the center fits over the hub. if the whole in the wheel is to big you should use hub rings, etc.
NAPA. Gyet suum.The_Chosen_One wrote:Good luck finding an OEM one from Nissan. Nissan stopped making and stocking/carrying parts for the CA engines like 2 years ago.
