captblue »
https://forums.nicoclub.com/captblue-u221599.html
Tue Jul 02, 2013 2:23 pm
OK , looked it up on link above and it's the notorious "new for 2000 and later models" grey body connector with the green slide tab. In the Service Manual, Section EL, Page 5, it is described as a "HARNESS CONNECTOR (SLIDE-LOCKING TYPE) WATERPROOF VERSION" but the manual only describes how to remove it off a terminal (simply push slide tab in and pull connector off of the terminal). The manual states that the "HARNESS CONNECTOR (SLIDE-LOCKING TYPE)" also comes in BOTH a waterproof and non-waterproof version. Each operates completely different from each other!!! Mine is the under-hood, engine type, WATERPROOF. The manual does not say anything about resetting/re-arming/reattaching the connector. When I took it off, I pushed/slid the "green slide" with a screwdriver till it clicked and stayed fully depressed into the connector before I pulled the entire connector off of the terminal. I don't think I actually broke it. The PROBLEM is that the "green slide" won't go back to the original position (still locked in fully depressed position). I have cautiously poked around on it looking for tabs/secret passage/magic button but no luck so far! Suggestions????
